Hi, I have a three phase system with Quattros where ACIN1 is connected to a three phase source and ACIN2 to a single phase source. I have tried to switch the inverter mode to charger only when ACIN2 is present but the inverter only detects voltage and doesn´t engage with the ac source. However, if the Inverter is in ON mode, it can engage with the ac source. Does anyone know the reason why the Quattro can´t connect in charger only mode through the ACIN2?
