Victon Energy MPPT 100/20
Panel Renogy RNG 100MB
LiFePO4 Deep Cycle 12V 100Ah Built-in BMS
I am just getting my feet wet with using a charge controller.
My battery is new and fully charged.
The Load setting is set to "Always On"
When I apply a small 12v pump to the Load, I would assume it would power from the battery. Instead the Load is powered from the solar panel. If a cloud goes by the pump slows down.
Thank you for your help.
Terrence
