Hi everyone,
Im new here and had my system (Multiplus II, 2*Pylontech 3000c, 8*400w Panels) installed about a month ago. I have questions.
While using the VRM portal I have noticed something strange happening in the "grid" block on the dashboard. The values there would constantly fluctuate between -100w and about 80w. This happens all the time. The historical values indicated 0w sent to grid and about 1kwh pulled from the grid every day. This system should not send anything to the grid and only pull from the grid when batteries reach 20%, which hasn't happened yet. Grid set point is 0w.
What does the negative values mean on the dashboard and why is the inverter still importing power from the grid when the batteries are charged and solar output is available ?
Many Thanks
MP
