Just installed my new MPPT 100-30 solar smart controller as a direct replacement for a previous identical model, and I have noticed the PV voltage is not stable - it seems to be hunting within a range of +/- 28 to 32 volts, which it did not do with the prior unit.
here is a quick video of the readout showing the changes by the second.
Video of the unstable PV voltage
the weather is cold and overcast, but not changing as fast as the PV voltage suggests!
do I need to be concerned?
