polarseal avatar image
polarseal asked
Venus Digital Inputs
I just noticed that the Venus GX allows for digital inputs via RJ12 socket. I feel a bit dumb asking this question but how does on get a device (e.g. bilge pump) connected in to a RJ12 socket? Is there a digital input device which i would connect deceive like this to, and then connect to the venus per the RJ12 cable.
Any information you could provide would be great, i would love to use this future but just dont have a full understanding how.
Venus GX - VGX
boekel avatar image
boekel answered ·
It's all here:
https://www.victronenergy.com/live/venus-gx:start#overview_of_connections
Basically: you can connect a switch between the ground pin and one of the inputs of the RJ11.
Works great.
I have also just made a change to that manual that @boekel has linked to:
https://www.victronenergy.com/live/venus-gx:start#digital_inputs
I am quite open to suggestions for how it could be further improved or clarified. Such as rough sketch diagrams, photos of installations or descriptions.
polarseal avatar image polarseal commented ·
Thanks! A bit more specific, would something like this work?
https://www.amazon.in/Generic-Terminal-connector-splitter-accessory/dp/B06XQ273JT
For example with a bilge pump would i run a wire from the bilge positive to the RJ12 digital 1 input? Would i then connect the ground to the main ground? (sorry but this is where i'm getting a bit confused).
boekel avatar image boekel ♦ polarseal commented ·
No you never connect a bilgepump or anything that's not isolated from everything.
what you can do is:
-use a separate float switch wired to the digital input
or
-use a relay in parallel with your existing bilgepump to provide an isolated contact for the digital input.
Ole Saether avatar image
Ole Saether answered ·
@Guy Stewart (Victron Energy Staff) If I want to use a digital input in a custom python script in Venus should I set it to Disabled in the gui?
