Hello.
Can anybody give me (or point me to) a proper explanation if the negative from the batteries (48V) and the negative from the DC-DC-converter out (12V) can/should be made common?
Im my case the 48V batteries will feed the MPII, the BMS however requires 12VDC, and therefor I will also connect the CerboGX to the 12V sytem, because this will be buffered - in case BMS shuts off 48V Batteries, the BMS and Cerbo will remain running for a certain time to see what is going on in the system.
If memory serves right, then the Cerbo can only be connected to all other units, if they use a common negative (-)/ground?
So: Common ground yes/no? Why?
Thank you.
