Although I set the maximum charge current via ccgx, the charge current is not limited. Only the current from the grid is restricted, but when the sun comes, it is added to the current from the mppt.
For example, I set the maximum charging power to 600W. 60V charging voltage. It limits the charging current to 10A only when the grid is present. But when solar energy is active, the charge current increases. Actually, I want to have a 10A limit. But my charge current goes up to 20A and more. How can I limit the flow of all energy from the sun and the grid?
