When every load is off on the boat, the input at the battery isolator argofet reads 4.4 volts. If I disconnect the house output, the voltage drops at the input to 2.2 volts. But, not, the output 2 terminal will also read 2.2. volts.
It seems that my outputs are actually pushing voltage through the isolator to the rest of the terminals.
Is this normal?
@Alexandra - Any thoughts? You were so good with the monitor :)
