Hi all,
I recently asked a question regarding the AC1 & AC2 out on the Multipluss II.
This question was answered to my satisfaction but it seems as if I have either misunderstood the entire picture OR I have somehow made a programming error / wiring error
In short:
1. I have a grid feed in
2. This grid feed in is monitored through an ET112
3. This feed supplies the Multiplus and "C"
3. I have split the distribution board into three . Lets call them AC1, AC2 (from Multiplus) and "C"
4. "C" comes directly from the supply (after the ET112)
5. "C" in other words operates totally independently of the Multiplus and the only indication that the loads on "C" exist is the reporting from the ET112 (Via Venus interface).
6. I am off the opinion that the loads on "C" are being drawn from the Multiplus / Storage batteries. This should not be the case. A geyser installed and load connected to "C" is drawing load from the Multiplus. Mistakes can be made but I'm 99.9% convinced its not a wiring problem (ie - inadvertently connecting the geyser load to AC2 for example)
I have installed identical Victron solutions and in those cases I do not have this problem. In one instance the client has a 10kw pottery oven and I sucessfully installed this solution on a Multiplus 48/5000. (the oven connected to "C")
