johnhise avatar image
johnhise asked
Best settings for Orion-Tr Smart 12-12/18 with sagging input voltage
I installed an Orion-Tr Smart 12-12/18 in my RV to charge a Battle Born lithium battery. The input voltage sags to 8.6 volts when it attempts charge. I assume because of the 10awg wire size. This causes the charger to stop charging, and begin an endless cycle of charging for a few seconds and then stopping. I can get the charger to charge by essentially turning it into a dumb charger by disabling the voltage checks. Is there any other thing I can do to more functionality from my "smart" charger?
orion-tr smart
trip-tracks avatar image
trip-tracks answered ·
You need to increase your input cable size. I am guessing they are a long run and being only 10AWG the voltage drop will be too severe. If it is a standard 5-8m distance (10-16m circuit), you want a minimum 6AWG, or even better, 4AWG.
You can trying playing with the settings but you are only working around the issue.
ronhanson01 avatar image
ronhanson01 answered ·
Increase the wire size, but then you can draw more amps then you think
