Just bought a cruising catamaran and I'm upgrading the power system. I'm on a steep learning curve, I want to use a Victron inverter/charger but not sure which one. I can see the difference is that the quattro has 2 ac inputs as opposed to 1 on the multiplus. I will have a DC generator and solar panels as the main charging system but I do have a Honda EU2200 as well.
My question is can I use the 2 ac inputs on the quattro as shore power inputs one for 230V and the other for 110V or does the voltage have to be the same or do I use one input for shore power and the other for the Honda?
How would I deal with the different voltages for shore power, do I need to add another component to deal with it?
