What is the lug/connection in the bottom right corner for? See image. Mentioned no where in the manuals or the drawings.
This site is now in read-only archive mode. Please move all discussion, and create a new account at the new Victron Community site.
I think it's for the earth/grounding cable point. The other side bottom left has a similar bolt and is labelled earth.
Could be a common or an isolated ground depending on how the PCB is laid out (sometimes when PCB are laid out common connections are mirrored) you could put a multimeter between the two to check but as marked by the symbol on the PCB/Case or as directed by the manual this should always be used as the grounding point.
24 People are following this question.
