Okay, so let me start off with "I am ignorant." and I mean that seriously. LOL I will do my best to supply all the info I can, but the vast majority of this stuff is a mystery to me.
So, what I have is 6x200w solar panels feeding 2x300mah Life Blue LiFePo4 batteries through the MPPT 150/100. It's installed in my RV. I'll attach a pic of the general set up. It was installed by RV Solar Solutions. I talked to the tech who did the install, he's stymied and recommended I come here.
11 days ago was the last time the batteries (according to the phone app) got any charge from the sun.....which is curious because we've had a LOT of sun lately. I did not fiddle with the settings, and the MPPT is not networked. I've attached pics of the set up and what I'm seeing on the app.
Any help is GREATLY appreciated!
Not sure if this is relevant, but just in case......
The screen from the app.....
The message I get when I check "Why is the charger off?"...again, the BMS is not connected to the MPPT.
Thank you again!!
 Another thing too - especially in moving installations you should regularly check the tightness of all exposed connections, in particular any that do not have locknuts, spring washers, etc. as they WILL loosen over time.
