Hi All, New to Victron, RVing and working with batteries. I'm installing a BMV 712 and the ASS000100000 temperature sensor on a 2020 Airstream with two Group 24 AGM batteries and the shunt will be installed in the battery box. The leads for the temp sensor are about 5 feet long but I'll only need about one foot. Can I cut the leads to length, tin the ends of the wires and insert into the connectors on the shunt? or does the sensor need a particular length of wire and resistance to accurately display temperature information. Appreciate your insights as I travel these uncharted waters.
