Guy.
Nice webinar. this is the person that participated from California (Kyle) My name's actually Bruce. I was using my son's PC and his name auto populated on the conferencing app.
System is a 24/5000/120 with 150/70 MPPT 1700W solar panels on an RV.
First section handles the BMS signals.
Second section turns on the AC out 2 circuit.
The rest is using the general flag to setup conditions for for mains to be used or not.
I'm using a BMV 700 to trigger the mains to be used if the SOC gets too low (relay closed) or turn mains off when SOC is above set voltage (relay open). This sets up solar as priority over mains.
All working good so far =)
Here's the part I can't seem to get to work...
With the AC out 2 enabled, I plug in my electric car on AC out 2, instead of the Multiplus turning on mains, it overloads the inverter and then restarts.
Help greatly appreciated.
Thanks.
