Trying to connect DIY 48V rack battery to MP II GX.
There was previously other smaller battery with not managed BMS working perfectly. Due to need for bigger capacity I repalced it with 16s 280Ah 12kWh batterypack.
From Basengreen CAN port pins 4-5 to MP Can port pins 7-8.
I can see in Settings - Services that packets are going in/out, I set in previous menu CAN port to 500kb/s BMS
What else can I do ? Do I need to worry about CAN bus addresses?
Basengreen USB tools says communication ok Victron type and address 1
I am expecting that battery device wuld appear in GX menu but it doesn' t !?
