I have a 10kva multiplus 2, and 42kwh battery bank, but when I use high loads of around 6kw (when cooking food, with hob, air fryer and microwave running at the same time) I find that the system draws about 3kw from the grid and around 3kw from the batteries, is this normal? Surely ess should never draw from the grid unless soc is low, but in my case it's over 90% soc. I have not set an inverter power limit, so the inverter should provide at least 8kw before the grid assists. How can I stop this high grid draw?
