Hi @all,
I've got the following setup:
- MPPT 250/60
- MPPT 250/70
- 3x MP2 3000 in 3-phase config
- CerboGX
- 3x Pylontech UC3000
Everything has the latest firmware installed, except the MP2. They are still on v497.
The setup works fine for about a year now. The Cerbo was the latest device that received a firmware update about 3 weeks ago. Since then everything worked as always. No config changes have been made for months.
Today I've noticed a strange behaviour. As soon as the battery reached 100%, the PV yield dropped to almost zero on both MPPTs even with a system load of about 2KW. the system did not even start discharging the battery. The battery stayed at 100%. All the system load was taken from the grid. That situation kept on going for nearly 2 hours and suddenly returned to normal.
Does anyone have a clue what happened here ?
When searching the forum I've found some similiar threads a couple of years ago. Back then the firmware had been updated to fix a bug. That happened long ago and should be fixed by now IMHO.
Thanks in advance
René
