I have a question pertaining to neutral ground bond.
I have a Victron multi plus II 24v 3000 watt 2x120.
My shore power is supplied by a generator with a neutral ground bond.
My understanding is the inverter bonds the neutral once Battery power takes over.
Ac out 1 is supplied by battery back up and shore power.
AC out 2 is a pass through when shore power is available.
I want to install a transfer switch between ac 1 and ac 2 to run my air conditioner.
The transfer switches I’m finding don’t switch the ground and only the hot and neutral.
So the only solution I see is to tie the grounds together from ac 1 and ac 2.
So the scenario I think I have is,
when ac 2 is supplying power the neutral bond relay in the inverter opens unbonding the neutral and power is supplied by the generator(generator has a bonded neutral).
When ac 1 is supplying power the inverter bonds the neutral.
When ac 1 is supplying power I assume the bonded neutral on ac 2 is still bonded at the generator.
In my mind this creates two bonded neutrals .
Could someone describe to me how this works?
