kamera-artatore avatar image
kamera-artatore asked
Multiplus, Shunt, Cerbo, Mppt and DVCC - problem
I have a system installed in my RV with Super-b LiFePO battery, Multiplus 12/3000, Mppt, SmartShunt and Cerbo gx. After some complications, the system works quite decently. However, I have a problem that I can't seem to fix.
the displayed voltage on the Muliplus (which I can see on the vrm) is consistently 0.4V lower than the voltage displayed by the Shunt, the independent battery display and my voltmeter (I took the measurement at the terminals of the Multi). in short, the installation is not the reason for the voltage difference in the display.
This means that Multi distorts the battery charging settings by 0.4 V. Until I lowered the charging voltage by 0.4 V in VEconfigure, the battery even reached over 15 V when charging.
Now the question: if he turns on the DVCC and in it only the SVS function (common voltage detection from the SmartShunt), is the battery charging protocol in the Multiplus preserved? Do the charging settings in the Multiplus remain unchanged and the Multi takes only another data about the battery voltage for processing?
Or does anyone have any idea why the Multi is showing 0.4V undervoltage in the first place?
thanks for your answers!
BR Tom
pwfarnell avatar image
pwfarnell answered ·
The settings in the Multiplus remain the same as programmed, SVS means it now uses the SmartShunt voltage so any error in the Multiplus or voltage drop.in the cables is ignored.
kamera-artatore avatar image kamera-artatore commented ·
Thanks for the reply - that's how I assumed it worked too...
I'll just turn on SVS in DVCC - hope it works...
However, I still don't understand why the wrong voltage information appears in the Multi if all the cable connections are OK? Maybe there is a cold joint in the Multi...
kevgermany avatar image kevgermany ♦♦ kamera-artatore commented ·
Could be a fault in the multiplus. Needs dealer testing to diagnose/confirm.
kamera-artatore answered ·
Yes, I will contact him…
