mets avatar image
mets asked
mppts load battery instead of transforming to AC
i have victron with Pylontech and MPPT´s (+PV) on DC side. And also an PV on AC side.
A Raspy is controlling and giving Multiplus the amount the battery should load or give power to AC side. This worked really well to set grid consumption to zero, before installing the MPPT´s (on DC side).
Now the multiplus doesnt give power to AC side, when there is a small power on MPPT. Then the battery is loading the small amount out of mppt instead of giving power out to AC side (what it is told to do from my raspy). (ESS is installed)
That is, why i buy power in the morning and also in the evening (small amount from sun) - even with full battery...
Does someone has a hint for that?
(When battery is full, it is transorming everything to AC side. Everything is working fine, when there is no power on MPPT)
Thanks
Multiplus-IIESSPylontech
