For the first time my batteries have hit 100% (I recently installed more panels)
I have 12kw of solar on the roof, 42kwh battery storage,
10kva multiplus ii
Mppt 450/100 and mppt
And a pv inverter 3kw
The system is configured as ESS and to only feed pv inverter into the grid, no victron power is fed into the grid.
The batteries finally reached 100% soc and both mpps turned off into absorption mode, and now my loads are all being powered by my batteries, and they are discharging even though the sun is shining and I have plenty of potential kw's on my roof. I thought the mpps would feed into the inverter and power the loads, like my pv inverter does. So what's going on here?
How much do the batteries have to discharge before the mppt's start to top them back up to 100%?
Is my configuration possibly set wrongly, or is it normal to use battery power once its100% soc
