Hello everybody,
Is it possible to create an AC-Grid via AC-Out with a Victron Multiplus, where Voltage and Frequency is selectable? E.g. 235V, 57Hz?
Best regards
Andreas
This site is now in read-only archive mode. Please move all discussion, and create a new account at the new Victron Community site.
Hello everybody,
Best regards
Andreas
Voltage yes, but as frequency you can only select 50Hz or 60Hz.
You can change the frequency to 57 Hz.
There is a virtual switch options page, where you can enter a cycle time. With this option you can get frequencies from 45 up to 65 Hz.
Additionally, you have to define the switch-over voltage or use virtual switch. You cant change the frequency permanently or by an external contol signal.
126 People are following this question.
