I have a Battery which is charged by solar with a BlueSolar 75/15. Now I want to add a Multiplus Compact 1600/70 which should charge the battery when it gets Power from the grid. Because both chargers at the same time does'nt work, I want to use the internal Relais of the Multiplus to switch off the BlueSolar, but I do not find a command for the relais to switch when Grid Power is on. Have I overlooked something or must I use an external relais?
Thanks
Ed
