graham-willsher avatar image
graham-willsher asked
Fronius control via Victron Venus OS and NodeRed
Good Morning,
I am looking at using a Fronius Primo Gen 24 Plus inverter and a Victron Multiplus II GX.
I know that they play well together, as the Fronius appears in the Victron VRM, and there is a joint webinar of the interoperability of these two manufacturers by Fronius/Victron.
What I am trying to find out is if any of the Fronius functionality is available within the Victron Venus OS (NodeRed) for control/programming purposes, on the same lines that you can run Nodered scripts to control the Multiplus's?
Any help or guidance would be appreciated.
TIA,
Graham.
Multiplus-IINode-REDFronius
Alexandra avatar image
Alexandra answered ·
@graham Willsher
Yes there is a way to control a fronius using node red. I haven't tried with a Gen 24 but have a primo.
The newer firmware on venus os large already has some built in.
FYI modifications has moved to https://victron.discourse.group/
graham-willsher avatar image graham-willsher commented ·
Hi @Alexandra ,
Thanks for the rapid reply. Hopefully it will have everything that I need in there.
Show more comments
