Since a few days I have my ESS running with 3xMPII 1xSmartsolar and Cerbo GX. The cerbo is running VenusOS 3.41 large with Node-Red enabled which I use to read my Homewizard 3 phase energy grid meter using the dbus-mqtt-devices plugin which is read every second. The cerbo is connected still via WiFi with a signal strength of -60dBm (according to unifi) will be switched to LAN cable this week. The battery is a smart BMS communicating via CAN.
But i'm have some issue that I get multiply times a day is that the BMS communication is lost for very short period, I noticed that when that happens the grid meter also disappeared in the console and I'm getting message that real-time is disabled in HRM.
So i checked the dbus-roundtrip-time and saw that there were large spikes every 4 to 6 hours, visually there seems to be a pattern (trying to upload a picture here but getting parsing response failed).
So the questions how can I find out what is happening
