chilepines avatar image
chilepines asked
Orion 12/12-30 non-isolated with low amp output
I have an Orion 12/12-30 non-isolated DC-DC charger connected to a starter battery, supplied by a 90A regular alternator. I'm charging a 300Ah LiFePo4. Alternator is putting out 14.4V. There is a 8AWG wire running 5 ft to the charger, and then a 10AWG run to the LiFeP. With the battery SOC at 76%, the charger goes into bulk charge mode at 13.7V, but my Victron Smart Shunt is showing at most 14 amps.
I tried changing out the connections - 6AWG direct from alternator to charger and 8AWG back to the battery - with no meaningful change in charger output. I've tried multiple setting changes including raising the Absorption voltage to 14.6, turning of engine shutdown and input lock-out - nothing changes the amps I'm getting to the battery.
Looking for advice on what I can do to get closer to 30A from this charger. I've looked through the forums here but have not found anything else to try.
battery chargingcampervanamps
chrigu avatar image
chrigu answered ·
The shunt measures that 14A are going into the battery, but that does not necessarely mean that the Orion is outputting only 14A. There might be a 16A draw on the system, totalling 30A supplied by the Orion.
If you chose the premade lifepo battery settings, then theres a 2hr limit on absorbtion.
chilepines answered ·
Thanks for the input. There are no other devices drawing from the battery. This is happening right from the start of turning on the charger so it is not a time limit. Also, my settings are not default as I’ve been working to solve the issue. Also, the charger is not hot, as it is just starting up.
VictronConnect VE.Bus charging manual
