I have a Phoenix 1200va Inverter (the small portable one) and will be connecting this to a small system with a Cerbo-s GX. (i will be connecting other bluetooth enabled devices directly via ve.direct cable like the smart shunt and 100/30 mppt controller)
Since the inverter comes with 1 ve.direct port out and NO bluetooth, i can choose to connect it directly to the Cerbo-s GX with ve.direct to access it through VRM, OR connect a ve.direct to BT smart dongle, to access the inverter through VictronConnectApp via BT directly.
It doesnt appear like i can do both since there isnt any Built in Bluetooth on the inverter like other smart devices that have both a direct port and bt.
1. Am i stuck having to choose GX vs VictronApp to interface with the Inverter? Will inverter show up in VictronConnect App if it is connected to the Cerbo-s Gx?
2. Is there any advantages of using one over the other? In practice (I get the gx will enable my system to talk to each other) will i need to be using VictronConnectapp anymore now that i have GX?
3. Is there any overlap in features for Inverter on the GX and VictronConnectApp?
Grateful for any insight.
