Rhys Cuff avatar image
Rhys Cuff asked
Multiplus at Full load most days, is this OK?
Hello
I have a 48v Mutilplus II, it will warn of impending overload around 8Kw (as designed)
I use the overload warning to connect to the grid if needed, this happens each day perhaps 2 or 3 times.
Is this a problem? sitting at the upper limit of the specification?
When does the warning trigger? 20% below overload or 20 seconds before the unit will actually overload? or some other trigger?
Should I just connect the grid at X amount of power draw? I didn't want to do this because output is affected by ambient temperature,
even if it connects to the grid with overload warning I notice it doesn't really draw from it until well above 8kw
Thanks very much for any comments.
Multiplus-II
