I have recently put together a system consisting of two Multiplus 2 x120V types for power assist functions in an RV.
When reviewing the System Overview and Consumption data it seems like VRM is not accounting for 2 inverters powering the system essentially halfling the power consumption in the graph and reporting this as "To Battery" instead.
Having reviewed the Advanced graphs, the "To Battery" isn't correct as the batteries are 100% charged and in float for extended times. I also deleted the installation from VRM and re-added. I monitored the data while away from the RV to capture the details while minimal power was being consumed.
I have checked all settings and also confirmed the Cergo GX does see the two serial numbers of the inverters.
Unsure if I am missing something or if this is a bug of sort. Will try attach screenshots, but the board is not allowing file attachments at the moment.
