sweeney avatar image
sweeney asked
IP67 12/137 re-entering bulk charging when voltage in battery drops
My camper uses 5-6 amps of power peak, usually 3-5 amp 5-6 amp. I am currently using a noco10 to charge, but it sometimes stops charging before the battery is 100% charge, and declares the battery damaged. Its not.
Also, once at 100%, the noco enterse float mode and will not restart charging if the voltage drops. The battery has gotten down to 40% SOC and I had to power cycle the charger to go back into bulk mode.
Victron's manual suggests using the battery while charging, as long as usage is "well below" one-third of its capacity. Your assumption meets this requirement: 1/3 of the rated capacity.
Also, will the P67 charger reenter bulk or absorption charging mode if/when the battery SOC drops, or is it necessary to manually restart the bulk mode of operation?
Thank you in advance....
SOCcampervanfloat
What is this noco10 device?
