Why do so many of the Multiplus inverter false high temp alarm (when no actual high temp exists) questions go unanswered/unsolved on this forum?
I have a Multiplus Compact II 2va that throws a high ambient temperature warning immediately after the transfer switch closes and charging tries to commence. It will indicate it is bulk charging but not put any amps in to the battery, and then at other times it will put a few amps in, before ultimately stopping again and repeating. I’ve also seen it throw a battery high temp sensor warning at the exact same time when clearly no issue exists their either.
Where is the ambient temperature sensor in the unit?
Surely someone has sent their unit in for repair; what was replaced or explained as the cause?
My faith in Victron has been greatly shaken by this circumstance, and I don’t want to lose trust.
