hi folks, a few years ago, I had a nice solar system comprised of a few panels, a Victron SmartSolar 100/50 with a Novopal 2000W inverter that was working beautifully for a few month, but it's been since, put in storage.
I've resurected the setup and it has been running fine, until I decided to update the android app, which also found two firmware updates, that performed them sequentially, without any problems, I believe up to 1.64.
It now appears that the SmartSolar Charge Controllers is spiking voltage up to 15.2 V at times (when the sunlight is brightest), into the inverter -- I don't think it manages the voltage capping well, anymore -- and it makes the inverter start intermittent beeping with an "error" and frequency 0, at times, at the DC In into the inverter reads back to 0V, etc, and then it resets and the cycle repeats. So I've stopped using the controller for the time being, being inclined to use the 100/30 backup controller that was also working fine (but without any firmware updates).
I'm having a feeling that the SmartSolar firmware updates are not behaving properly, as, when I disconnect from it, the inverter works beautifully, with any errors.
Has anyone encountered firmware update issues with the SmartSolar Victron Charge Controllers and if so, how can I downgrade the firmware, if so?
thank you kindly,
Cos
