jeanclauderuehle avatar image
jeanclauderuehle asked
Cerbo GX WIFI Dongle Setup
I'm using a cerbo gx but the wifi singal to the interne router is to weak to have a stable connection.
To increase the signal strength, I'm using the recommended Victron Wi-Fi dongle, but I can't find any information how to set it up.
The dongle appears on the Cerbo GX Wi-Fi connections as venus-HQ2247..., and I'm able to use it, but I found no way to connect to the existing internet router.
Thanks for your help.
Jean-Claude
cerbo gxwifi
Alexandra avatar image
Alexandra answered ·
@jeanclaude.ruehle@gmx.ch
It is plug and play.
https://www.victronenergy.com/media/pg/Cerbo_GX/en/internet-connectivity.html#UUID-9d932e2e-f182-1ab9-a574-34c2fffecb9d
The connection to the router is done the same way the internal WiFi is done.
jeanclauderuehle avatar image jeanclauderuehle commented ·
@Alexandra
Thanks for your answer and means that I have to plug in and do nothing more?
I did it this way but the signal strenght remains the same as before.
Does it mean I plug it in and add it with the shown passphrase as WIFI-connection as I did the connection to the router?
Thanks again for your help.
Regards, Jean-Claude
Alexandra avatar image Alexandra ♦ jeanclauderuehle commented ·
@jeanclaude
If it one of the tested ones on the list, there is nothing more to do except enter the router WiFi password as you did previously.
