I had this problem in December 2023.
I'm having it again after updating to Victron Connect 6.07. I can no longer export or import a configuration file. (Multiplus II, 24/3000/70, 120 VAC.)
If I recall correctly, the problem last time was that Victron Connect didn't fully work with 120 VAC USA units.
