Hello all, I think my terminal block for the analog devices (in my case temp sensors) no longer are connected correctly. I need to verify the "connection", I was trying to disconnect/remove one temp senors cables and I might have somehow broken/disconnect the terminal block when attempting to remove the cables, the cerbo is mounted in a really not user friendly space in my boat... Any ideas/suggestions!
