Willem avatar image
Willem asked
Multiplus-II 12/3000/120-32 looks dead.
Device is no longer visible in the Cerbo GX.
Cerbo GX: Firmware: v3.41; v3.40 in backup
Multiplus: Firmware 552; Product ID: 2605; VE.Bus connection; Single unit; VRM instance: 276
The last connection was 27/07/2024 at 17:53:46
The dc-power supply works: 13.3 Volts measured. AC power supply also works: 227V measured. Everything measured at the connection points of the Multi.
The VE. Bus connection disconnected from the BMS.
Via MK3 interface on VE. Bus checked if a connection was possible. Didn't seem to connect. Not on DC and not on AC power.
Reset tried but no response.
Visually, there is nothing to see about the device.
multiplus ve.buspre rma
Alexandra avatar image
Alexandra answered ·
@Willem
If you have done all the basic testing, and you still have a dead unit (all internal connections /assembly checked) then you can return for a warranty repair. Or just a repair maybe it depends on what is dead there.
Willem avatar image Willem commented ·
Well with help of a Victron servicecenter problem solved. The bridge on the connector for swichtching on and of on a distance has a loose contact.
So thanks for your help.
Show more comments
Pre-RMA Bench Test Instructions
