I recently purchased the Victron wall mounted enclosure for the MPPT Control display. A ve direct cable is used to connect the display to a MPPT 100/30 controller. The enclosure has a port for multiple wires and not the ve direct cable. If I drill out the port enclosure to wire the direct cable to the control display, do I void the warranty on the enclosure ? Everything fits the enclosure and connection to the display device. Thanks for any clarification
