gmdorf avatar image
gmdorf asked
Multiplus Compact 12/2000/80-30 generating fluctuating AC loads
c0619ab3c344_inst_ttyS4_Interfaces_Mk2_Tunnel (3).pdf
I have a Multiplus Compact 12/2000/80-30 build into my VAN powered by 2 Victron Smart Lithium Batteries (330ah) and the Smart Lynx BMS.
When I connect a AC load of 1600 Watt, the inverter pulls 1600Watt and drops to 800Watt goes back to 1600Watt and drops again in a 1 second Interval. When I look at the inverter I see the alarm (without notification) pop up every second as well.
I have configured the Multiplus like in the file attached. (I changed the file encoding to .pdf as the form wouldnt accept rvsc files. Please change back to .rvsc)
Does anyone have an idea why this might happen?
Many thanks in advance.
Multiplus-IIinverter current draw
nickdb avatar image
nickdb answered ·
What is the load?
gmdorf avatar image gmdorf commented ·
I am assuming your are asking for the ac consumer? It draws 130ah (1600Watt) from a 12V System
