nova avatar image
nova asked
What programming do I need to change on mult plus 12-3000 for lifepo4 batts.specifics please
I’m installing 2 330 ah 12.8v lifepo4 smart batts with a smart bms 12/200 .i’ve read the manual it doesn’t say how only that it’s possible. Thanks. And what are the specs for the batts
Multiplus-II
1234enough avatar image 1234enough commented ·
  • Good question - what are the specs of the battery's- would need a bit more info to determine that. Feel you need to read the manual again and maybe the vast array of victron literature available to learn how to / what to set / where / how.
pwfarnell avatar image
pwfarnell answered ·
All Victron devices have a lithium preset option that is set up for Victron Lithium Smart batteries. On the Multiplus DO NOT choose the option Lithium with VE Bus BMS and do not select any boxes with VE Bus BMS options.
