frankvw avatar image
frankvw asked
Which programmable relay to use for Multiplus in VEConfig?
My Multiplus 24|800|16 has (AFAIK) one programmable relay. Which option in VEConfig should I use to program it? I assume it's the "primary" one but I'd rather be sure.
Multiplus-IIVEConfigure 3Relay
@frankvw
If you look at the relay it is labelled.
The primary one is the one that accepts grid. So if that is what you are trying to control then use that.
frankvw avatar image frankvw Alexandra ♦ commented ·
Not sure where to look; I didn't see anything labeled. I'm trying to program the relay that by default is configured as an alarm relay:
As per the manual: "The Multi is equipped with a programmable relay that by default is set as an alarm relay. Therelay can be programmed for all kinds of other applications however, for example as a starterrelay for a generator."
(I.e. the relay connected to "E" in the above image. I'm not trying to mess with the internal backfeed safety relay or the ground relay. (In fact I want to avoid accidentally doing anything with those at all cost!)
