I have create a simple solution to allow the control of the hot water immersion heater based on the state of charge and / or the current grid load for a victron system. For example if the SOC is 95%+ the immersion heater kicks in, but if the kettle goes on and the draw from grid increases then it stands by. If the system has excess solar then the tank heats up before sending to grid.
The solution needs no direct wiring into the solar system to work - it relies on the VRM API.
The only potential wiring is to use pretty much any home automation device (shelly, kasa, wemo etc) to control a contactor (relay) that in turn controls a 3kw immersion heater. This is similar in complexity to wiring a simple "timer control" to the immersion.
I've developed a simple app to for manual boost / on / off and to monitor the history remotely.
I'd like to know if anyone is interested in helping in the Beta stage of this project. There's no expensive equipment to buy.
If anyone is interested or would like to know more please drop me a line here.
Cheers
Jon
<personal info removed. Moved to mods>
