What is the cause of Battery Monitor (512) State of Charge alarm in a Victron setup and how can it be resolved.
This site is now in read-only archive mode. Please move all discussion, and create a new account at the new Victron Community site.
There are two ways to set it up.
One is on the bmv itself with Victron Connect and one on the VRM.
The reason for an alarm on the BMV712 is most likely that the batteries it looks at have gone under the set alarm value, i.e. state of charge less than 50%.
There are actually three ways you can set it up (and change the alarm value) if I have understood it correct:
On the BMV itself, via the VictronConnect app and via VRM if you have a Cerbo GX or similar.
What is '512' on your system? On mine it's a managed battery - which is also listed as a 'Battery Monitor' on VRM.
75 People are following this question.
