I have a new as of February 2024 and now it is rebooting as often as every 15 minutes. The longest up time that I have seen is just under two hours.
Some background. I am running two multiplus II 24-2x120 in parallel. The system was very stable until this February. In February, I lost communication between the Touch 50 and the Cerbo GX. It was determined that the original Cerbo was malfunctioning and it was replaced under warranty.
As part of the replacement, the firmware of the Cerbo was updated to v3.31.
In January before the replacement and the updates, we spent two weeks boondocking in the desert. The daily generator running went perfectly.
After the update, I had to change a few connections to get the generator back online and working with the new warm up and cool down times available with the new software.
Now, because of the Cerbo rebooting, the generator will not run for two hours without shutting down at least twice due to the Cerbo rebooting. The Cerbo GX relay 1 picks to start the generator and drops to stop it. When the Cerbo reboots, the relay drops stopping the generator, I believe, and the relay picks again once the Cerbo is back online.
In searching other posts, it appears that this is a know issue. I have not found any report that it has been corrected. I did see that updating to current stable firmware was suggested as it might help. I updated today to v3.34. The Cerbo continues to reboot.
I have ssh into the Cerbo and run the top command. Before the firmware update, the cpu was typically running @34-45%. Now the v3.34 software is showing cpu 64-68%.
"Reboot device when no contact" is OFF.
Any help or suggestions would be appreciated.
