gentoo avatar image
gentoo asked
EV charging station screen rebooting with system data error
My ev charger from victron just arrived - and it was working correctly until i connected it to the internet and it upgraded to 1.29 version - then after upgrade there is problem with screen . it is booting over and over with information on screen like "System data error". Was trying to update it 2 times with C25 version and C24 version but nothing helps.
victron productsevcs
6 comments
Hi, when restarting, is it trying to update the screen firmware?
gentoo avatar image gentoo Lucian Popescu (Victron Energy Staff) ♦♦ commented ·
After what type of restart ?
Normal with power off/on or with restart after updating ? or soft reboot from app- i can check then
power on/off
cant catch any information ... it blinks just after restart with system data error. today was updating it with 1.29 firmware few times to check if there are any info on screen but maybbe there are but to catch them you need camera with like 50fps to catch some stuff :)
gentoo avatar image gentoo gentoo commented ·
also no matter if BT is on or off when updating when nobody is connected thru BT. When BT is connected then yes sometimes firmware update can stuck at 50%. But my device website is working correctly just the screen is blinking all the time and everybody is asking me what the X is that :)
@gentoo Check your email please
woudpro avatar image
woudpro answered ·
HI same here tried all the tricks suggested.
Keeps showing error, all else works fine
Vrm portal id c0619ab55993
WoudseHoevePower
Appreciate the help.
Greetings Richard
woudpro avatar image woudpro Lucian Popescu (Victron Energy Staff) ♦♦ commented ·
Thanks, I again tried a power cycle and for some reason it started the update of the lcd and finished successfully.
Problem solved...
Richard
It is probably not solved. I recommend you to arrange for that driver.
The parameters can vary based on temperature, so you probably tried when it was colder. But as you wish.
Lucian
