Hi Everyone,
I'm having an issue with my MultiPlus-II 12/3000/120-50 2x120V. We're at an older campground and we have a 30A single-phase power connection. I set the input power to 27.5A. It worked fine for about 24 hours and the breaker tripped outside, twice. Maybe because of the low voltage? That might have made the 27.5A too much. The inverter went into overload despite it not assisting at the time.
Now, I'm not getting any AC input or AC output readings on the GX screen and the AC input limit is not working. I set it all the way down to 15A and it's pulling nearly 32A so I can't get it to stop tripping the breaker. I've already reset the entire system by cutting AC power, solar, and disconnected the batteries and this didn't help.
I can also confirm this behavior via VE.Configure on the laptop. The Multiplus is receiving the input limit and the erroneous numbers match.
Any help or advice is greatly appreciated!
