Dynamic ESS. I have just signed up to Octopus flux tariff (UK) which varies both for import and export during the day and I would like to program ESS to take full advantage, I am somewhat daunted as to how to do this and any advice would be very welcome.
What I wish to achieve is as follows
1 if the battery at 24:00 hours is less than full then it would charge at the cheap rate between between 2 – 5 at night
2 during the period between 2 – 5 battery will not discharge to the consumer unit
3 that say 6 kilowatt hours (the estimated baseload for this period) will only discharge to the consumer unit between 16 – 19 hours which is the peak charging period for import from the grid
4 any surplus held in the battery above 6 kW will be discharged during the day.
This is possible and how do I do it!
