I just installed a system with a MultiPlus-II 48/5000/70-50 and a Pylontech US5000.
They are in separate locations, meaning there is a door dividing the inverter and the battery. I started noticing a low humming noise coming from the battery (similar to the one made by the inverter, but not as loud). Maybe it was there from the start and my excitement drowned it out. Since they are divided by a door, I can tell the noise is indeed coming from the battery, not the inverter.
I measured it with my phone, it reads 38-39db with the Multiplus in "Inverter Only" mode and 42-43db with the the inverter in "On" mode (even though I have enough PV power and don't pull more than a couple of W from the grid).
If I turn off the Victron switch which I have on the plus cable leading to the battery, the buzzing goes away (battery still on).
Is this normal behavior?
Note: The first two days, the Pylontech battery was not connected to earth (if it makes a difference). Now it is.
EDIT: https://streamable.com/6dk9uw (a video with it)
Thank you.
