Hi, my Orion XS appears to be charging even when the bms states 100% charge. Can someone please confirm the following
A) Orion XS connected via VE cable and ATC to H Pin from BMS?
B) Orion XS set to engine shutdown detection set to off
This is my setup whilst driving yesterday
Setup is 3x160A 12v smart lifepo4 into a lynx distributor (A)
Lynx smart BMS connected to daisy chained 3 batteries
Lynx distributor (B) with Orion XS and Smart MPPT on one fuse channel and Victron battery protect 220A on number two fuse channel
Cerbo GX with screen
Netgear MiFi Ethernet connected
Multiplus II 3000 waiting for correct size cables
many thanks in advance for help with correct config and setup
