so I have five solar panels rated at 40 V open circuit and 370 watts in my solar computer is telling me I'm making 40 A at 14 volts and I'm currently trying to run a 6000 W converter that hooks up to two of my three battery storages and I'm using just over 800 W on the inverter and I've read that the best way to increase your wattage is to increase your voltage I just wanna make sure there's not any other ways that I can do that to increase the watts I believe at 14 V 40 A is right around 600 watt and I'm trying to figure out if I am putting the solar computer at to low of a voltage and if raising it to 40 will increase my power but I'm also concerned that if I do raise it to 40 will that be too much for my batteries or does the computer still only put 12 V into the batteries?
